2024-04-23 7:11 AM
we use STHS34PF80 sensor as little animals detector (FOV ~ 20cm) and we have problem with false motion detection on outside. When we have sunny day the sensor goes crazy and output random MOT_FLAG signals. We have try to change LPF_P_M and LPF_M filters but without success. Also we try to change motion threshold and motion hysteresis also without success.
Is any solution for this problem?
Thanks in advance
Adam Socha
2024-04-30 2:45 AM
Hi @socha6 ,
Welcome to ST Community!
STHS34PF80 is based on IR technology and using it in outdoor applications you could have some unexpected IR reflections which cause more noise.
2024-06-12 4:37 AM
@Federica Bossi we know that, but we are looking for solution. We need to eliminate that problem.
We are a startup developing IoT devices. We are currently closing the prototype phase and starting mass production. Planned volume of devices - 20 million by the end of 2029.
2024-06-12 7:22 AM
Hi @socha6 ,
You should open a ticket to our online support so that they can help you for your specific case.
Here the link: https://ols.st.com/s/
