2020-11-19 5:11 AM
The datasheet reports an offset drift TCOff of max. 0,4mg/°C.
We made temperature tests with 3 samples and found the offset drift beeing 0,17 ... 0,58 mg/°C so higher than allowed. Does this meet your expectations?
Can you share your measurements?
Thank You
2020-11-26 7:28 AM
Hi Gerhard,
I was just comparing the title of your post where you wrote "IIS3DHH" and the actual device that is, correctly from your picture, a IIS3DHHC.
Thanks,
-Eleon
