IIS2DH capacitors to VDD line
Posted on January 28, 2018 at 00:34
Is it mandatory that 100nF and 10uF to the VDD line has to be ceramic and aluminium respectively?
Also, we had three custom boards built with IIS2DH. Surprisingly, all three were giving a different XYZ values when kept in the same orientation. Please give me some suggestions as to what I have done wrong or in what I could do to mitigate this problem.
Thanks,
Ranjith
#iis2dh
1 REPLY 1
Posted on January 28, 2018 at 01:16
How different? Do you save any calibration data based on testing in a uniformly aligned test fixture? Do that parts lay flat on the PCB, and exactly the same orientation?
You want the bulk capacitor to have a low ESR so it can deliver instantaneous current without resistance. While the material/construction will impact the ESR, it is the ESR that should be the parameter used in the selection.
