I 'm currently using ASM330LHB sensor, I hopes provide me with some driver example program.
wzhen.2
Eleon BORLINI
Hi @wzhen.2​ ,
ASM330LHB is just the ASM330LHH ASIL-B part number. You can then use C drivers on Github --> asm330lhh_STdC.
If otherwise you need also other sample code, you might refer to the device software page (LINK) or to this partner page for the ASIL-B drivers.
-Eleon
Eleon BORLINI
Hi @wzhen.2​ ,
-Eleon
wzhen.2
Hi Eleon
​I have download the asm330lhh drvier package from above link last day, and i checked the register map with asm330LHB, it is same. Thank you for your quick response,
-zhenwei
