I am using Sensortile.box and I downloaded the FP -Sensing pack to see the sensor functions. I connected thro BT the application is working fine . I connected the same module with Teraterm with UART configuration - 115200 Baudrate but it shows error
Snara.21
Teraterm Issue
TBomb.1
Senior II
Hi, the FP-AI-SENSING1 is designed for BLE communication; if you are interested in streaming data via VCOM with the SensorTile.box you should use for example the FP-SNS-STBOX1, where the DataLogExtended should stream data on USB.
https://www.st.com/en/embedded-software/fp-sns-stbox1.html
https://community.st.com/s/question/0D50X0000BBp2PK/sensortilebox-how-to-stream-data-from-lsm6dsox-over-usb-win1064bit
Tom
5 REPLIES 5
TBomb.1
Senior II
Tom
Snara.21
@Community member​ Thanks for your immediate response.. I will download and validate
JGies.1
is there also a way or isntructions for how to get access to the usb serial data without the incleo-gui? ideally to a linux system?
Snara.21
@JGies.1- How about using USB to UART Convertor boards available in FTDI
Snara.21
@JGies.1​ How about using USB to UART Convertor boards available in FTDI. It is working fine.
