How to use STEVAL-MKI109V1 command in terminal ?
eric-1024123
Posted on August 27, 2014 at 08:35
I want to utilize command in STEVAL-MKI109V1 board.  STEVAL-MKI108V1 is insert on the  STEVAL-MKI109V1 board, I utilize user guide to set up. Bur terminal can't receive any data? How do I slove the problem?
#mki109v1 #mki108v1
rob239955
Posted on September 08, 2014 at 15:30
Same here.  I have the LIS3DH module on a STEVAL-MKI109V2 motherboard.  Version is 3.0.5
Can you get some of the commands to send you back responses?  I can get the following to work for me:
  • *ver
  • *list
  • *listdev
None of the others.
