How to generate header from .ucf file?
YRakh.1
could you please clarify one topic for me. I am working with lsm6dsox sensor. How can I create a header (.h) file instead a .ucf to easily include in a project?I read that it is possible using Unico, but i didn't find this option in it. (Unico 9.3.0.0 is used)
best regards
YRakh.1
found it. Unico-> Options-> C code generation... Then select ucf file and header with same name (and struct name also) will be generated to the same folder
YRakh.1
