Hi, we plan to use a TOF sensor to measure a part distance out door , the reflector size around 30x15mm, the working distance range can be 0-180mm or 50-230mm or 100-280mm, the expected accuracy is less than 2%, can you hep to recommend one?
GQiao.1
Psmit.2
Your question is all about very detailed numbers, which requires careful calculation so I am not sure if it is correct to introduce you.
ACHOU.18
You can check VL53L0X , especially your usecase is out door and max range is 28cm. you could have a look on ranging peformance of this product.
https://www.st.com/en/imaging-and-photonics-solutions/vl53l0x.html
Aditya
