Piotr Romaniuk
May 26, 2018
Why SCAN-REQ event is not sent?
Posted on May 26, 2018 at 11:37
I am using BlueNRG-2 chip with DTM firmware. It is connected to host processor STM32 by SPI.
This bluetooth device works in peripheral role (some sensor).
Advertisement works fine: another device that is a master receives ADV_IND messages as well as SCAN-RSP, that I set in sensor.
I have a problem with SCAN-REQ event, it is never sent by BlueNRG-2.
Firstly, I observed aci_hal_scan_req_report_event() that I defined in my software. It is never called.
Next, I verified that even on SPI this event is not sent.
Why is it like that? Should I enable this event report somehow?
Piotr Romaniuk
#scan_req #bluenrg-2 #dtm #event
    Piotr Romaniuk
    Piotr RomaniukBest answer
    May 26, 2018
    Posted on May 26, 2018 at 14:43
    I found the solution.
    According to BlueNRG Bluetooth LE Stack documentation, in new features list:
    'ID 2558 Added new event notified to the application when a scan response is sent to a peer device (it is disabled by default)'
    In order to enable it following function must be called:
       aci_hal_set_event_mask( 0x00000001 /*ACI_HAL_SCAN_REQ_REPORT_EVENT*/ );
    I hope this will be usefull for others.
    Piotr Romaniuk
    1 reply
    Piotr Romaniuk
    Piotr RomaniukAuthorBest answer
    May 26, 2018
    Piotr Romaniuk
