2025-02-05 07:40 AM
Are there any samples I can order? I don't see it listed on any of the distributor sites. If anyone knows where I can get one that would be great! Also, if an ST rep can state when they will be available to order that would also be great!
2025-02-05 07:57 AM
The community is a forum for mutual help between users, which can also be seen as a reference work for solvied problems.
For questions about availability you should contact your local distributor or sales office, alternatively create a personal ticket in the Online Support OLS.
Good luck!
/Peter
2025-02-05 07:57 AM
Good luck!
/Peter
