2026-05-19 4:24 AM
Dear all,
is it possible to measure the frequency of the 32,768kHz oscillator (external crystal used) at a buffered pin similar to the MOC pin of the STM32 to tune the frequency by the external capacitors? It would be difficult to do this at pin XTAL32k_IN/OUT without influencing the oscillator frequency.
Best regards,
Peter
2026-05-19 5:37 AM
Hi @PKR
The 32 kHz clock signal cannot be routed on a GPIO to perform such measurement.
2026-05-19 4:36 AM
There is a divided output - check you processor data sheet
2026-05-19 4:58 AM
I could't finde any hint in the ST67W611M1 module / QCC743 SoC datasheets. Could you provide details?
2026-05-19 5:37 AM
Hi @PKR
