ST67W611M1 AT+CIPSTART documentation incomplete
xJIomqygrecz
The API documentation for the "AT+CIPSTART" command on the ST67W611M1 chip seems to be incomplete. It is missing the parameter lists for UDP and SSL types.
https://wiki.st.com/stm32mcu/wiki/Connectivity:ST67W611M_AT_Command#AT-2BCIPSTART
The rest of the API is documented on the ESP-AT page:
https://docs.espressif.com/projects/esp-at/en/latest/esp32/AT_Command_Set/TCP-IP_AT_Commands.html#at-cipstart-establish-tcp-connection-udp-transmission-or-ssl-connection
YBOUV.1
Hi @xJIomqygrecz ,
documentation has been updated here
Please note also that latest X-CUBE-ST67W61 v1.3.0 has been released.
Best regards,
TarikAb
Hi xJIomqygrecz,
Thanks for letting us know. We will update the description which by the way is now here.
Best regards,
YBOUV.1
Hi @xJIomqygrecz ,
Best regards,
