ST BLUENRG-LP Bluetooth as a slave machine, how to forbid the other host to initiate the pairing request, I want to only allow the slave machine to initiate the pairing request
Fx.1
ret = aci_gap_set_io_capability(IO_CAP_NO_INPUT_NO_OUTPUT);
ret = aci_gap_set_authentication_requirement(BONDING, MITM_PROTECTION_NOT_REQUIRED,
SC_IS_SUPPORTED,
KEYPRESS_IS_NOT_SUPPORTED, MIN_KEY_SIZE,
MAX_KEY_SIZE,
USE_FIXED_PIN_FOR_PAIRING,
PERIPHERAL_SECURITY_KEY);
0 REPLIES 0
