SPWF04S configuration variables from uPython
Dominic Moffat
Posted on November 06, 2017 at 18:32
Hi
How do I get access to the configuration variables (eg, standby_enabled etc) using a micropython scripts. Also how do I commit the variable changes to flash?
Best Regards
Dom
Gerardo GALLUCCI
Posted on November 08, 2017 at 18:32
Use the machine class. Methods config (AT+S.SCFG-like), config_store (AT+S.WCFG), config_reset (AT+S.FCFG)
Posted on January 08, 2018 at 03:25
How did you know this command existed. I can not find any documentation that called out these methods. I've look on the upython wiki and the ST site. All I can find is the AN4964 document which doesn't have these methods called out. I would like to do some other things but I don't know what is available and I would like to explore using the SWPF04 chip as a hostless part.
Posted on January 09, 2018 at 12:19
You can use the TAB key within the REPL mode to get auto-completion and the list of supported methods
