2016-10-18 5:17 AM
UM1695 mentions that there is a special test mode that is enabled via configuration variable ''eft_mode''. Description says ''Enable/disable the Engineering Test Functions. It is used for controlling the radio for thecertification
tests (disabled by default=0, enabled=1)''. However I cannot find any more documentation on this. Typically in these tests we would like to select the channel and transmission and jut send some data patterns in order to measure the antenna implementation etc. How are these controlled when test mode is enabled?2016-10-18 1:15 PM
Hi Jarno,
there is a specific document describing how to handle test mode. Please contact your local distributor, or local ST support, to get this manual.
jerry
tests (disabled by default=0, enabled=1)''. However I cannot find any more documentation on this. Typically in these tests we would like to select the channel and transmission and jut send some data patterns in order to measure the antenna implementation etc. How are these controlled when test mode is enabled?We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
