2018-02-09 6:05 AM
Hi all,
I would like to integrate the SPBTLE-1S bluetooth module in a new own PCB design. I want to connect the bluetooth module with a STM32F215 MCU through I2C interface.
I have performed the schematic following the datasheet recommendations. Could anyone help me and check if SCH it's ok?
Thanks in advance.
Bests regards!
2018-06-07 4:38 AM
Hi Mitja,
if you're using
SPBTLE-1S,
when you build your project, make sure that you defineHS_SPEED_XTAL=HS_SPEED_XTAL_32MHZ
In another thread I have found your request about how to change the crystal settings. I have replied to it and now you can find details about how to do it in your IDE here:
https://community.st.com/0D70X000006T1MmSAK
Best regards,
Antonio
