How to safe file in to the external flash of SPWF04SA wifi module
Andrea Ortogni
Posted on June 07, 2018 at 09:21
I'm using a SPWF04SA wifi module.
When I create a file (for example sample.json) with AT+S.FSC command the module saves that file in its ram memory.
How can I save that file in the internal or external flash memory ?
Thanks in advance !
#ram #wifi #flash-storage #spwf40sa #file
0 REPLIES 0
