S2-LP transceiver kit - STEVAL FKI868V1 - can we use balun
Silas Valera
Posted on November 04, 2017 at 19:07
Hi
I received 2 of this kit, and I ran some basic tests - works really fine!
I am trying to use S2-LP in wm-bus solution for my project. I have a question regarding redudcing the capacitors/inductors count on the PCB : is there any chance to use balun (say with a freq range of
850MHz ~ 915MHz
https://cdn.anaren.com/product-documents/Xinger/BalunTransformers/B0809J50ATI/B0809J50ATI_DataSheet(Rev_A).pdf
) ? And if yes, how would that change the circuit ?
Thanks in advance!!
Silas
#s2-lp
5 REPLIES 5
indar singhal
Posted on November 07, 2017 at 17:43
Hi Silas,
Good to hear that you are using S2LP device.
We are currently integrating the Balue (BALF-SPI2-01D3) with S2-LP and making new Nucleo expansion board. We are validating the first prototype. S2LP package will be available on ST.com by end of Q4 or early Q1.
Meanwhile, please referrer the piece of schematic below which may be useful for you.
BR,
Indar
________________
Attachments :
S2LP_with_Balun.PNG : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HyKa&d=%2Fa%2F0X0000000b66%2FLsGvNaOulQR1uhS_EJ52xAqzQwqmm0_bbKrelrOmIHI&asPdf=false
Posted on November 08, 2017 at 00:31
Hi Indar,
Thank you so much for your reply and the schematic with balun, this really reduces the component count and simplifies the design!
Well, further looking up more information on this particular balun you mentioned, it seems this is an ST product and specifically customized for S2-LP !!!! Wonderful!! And the data sheet is also available (
http://www.st.com/content/ccc/resource/technical/document/datasheet/group3/e9/ff/cd/1e/4f/dd/49/b4/DM00417488/files/DM00417488.pdf/jcr:content/translations/en.DM00417488.pdf
) with the schematic!!  I am sure the schematic must have been tested.
One more question:
Can we do this schematic on two-layer pcb? Or do I need to do 4 layer?
Thanks again,
Silas
Posted on November 11, 2017 at 20:26
Hi Indar,
For the reference data sheet ofBALF-SPI2-01D3
/external-link.jspa?url=http%3A%2F%2Fwww.st.com%2Fcontent%2Fccc%2Fresource%2Ftechnical%2Fdocument%2Fdatasheet%2Fgroup3%2Fe9%2Fff%2Fcd%2F1e%2F4f%2Fdd%2F49%2Fb4%2FDM00417488%2Ffiles%2FDM004174pdf%2Fjcr%3Acontent%2Ftranslations%2Fen.DM004174pdf
)would you please help for some clarifications:
1In the schematic in figure 9, there is reference to jumpers JP1 to JP5, but is no such jumper in the schematic.. would you please provide some information on this?
2. The reference data sheet is marked with date 'Aug 2017' at the bottom on the first page, is there any updated version of this reference data sheet? Would you please help. ..
Thanks again
Silas
Posted on November 14, 2017 at 06:36
Hello Indar
Will you please provide any update on the above..?
Silas
Silas Valera
Posted on November 22, 2017 at 04:14
Hello
Anyone has worked with this balun (
BALF-SPI2-01D3) with S2-LP? I would really appreciate any information on the schematic given in the datasheet of the balun. I am planning on using S2-LP and possibly with this balun.
Thanks in advance!!
Silas
