Is there a CLI version of the BlueNRG Flasher Utility?
Marcos Frid
Posted on October 04, 2017 at 20:59
I need to flash the firmware into a BlueNRG-1 through the chip's UART.  This functionality will be run from a Windows executable for factory automation.  Thank you!
#bluenrg-1
Marcos Frid
Posted on October 04, 2017 at 21:09
Alternatively, if there is a *.map file for the BlueNRG-1 for the CLI version of STMFlashLoader, I could use that as well.
