Is an external mcu required to program BlueNRG-M2
COlva.1
I am working on a project on which I want to recover data from another BLE (Bluethoof Low Energy) sensor. I found the module BlueNrg-M2 to be good for my application but I don't know if I need an external mcu to program it. I really need your help !
If someone have already worked with this module, it will really be helpuf if i can know how to make the connections between a sensor, the module and the mcu (if needed).
ChahinezC
Lead
Hello @COlva.1​,
I am not an expert in the BlueNRG, but I recommend you checking the How to program BlueNRG-1 and BlueNRG-2 devices article.
Chahinez.
COlva.1
Thank you @ChahinezC​ , I am going to have a look at on this article. Hope it will answer all my questions.
