Hello, I tried to mix BLE+mesh using IDB05A1 and stm32L4. I used light demo example and added a custom service, but I cannot interact with it because I cannot find the way for integrating my custom service callback. Is it possible? Thank you
mavv
mavv
Finally I solved it by calling "user_notify()" at HCI_Process():
void HCI_Process(void)
 tHciDataPacket * hciReadPacket = NULL;
 Disable_SPI_IRQ();
 uint8_t list_empty = list_is_empty(&hciReadPktRxQueue);
 /* process any pending events read */
 while(list_empty == FALSE)
  list_remove_head (&hciReadPktRxQueue, (tListNode **)&hciReadPacket);
  Enable_SPI_IRQ();
  HCI_Event_CB(hciReadPacket->dataBuff);
user_notify(hciReadPacket->dataBuff);
  Disable_SPI_IRQ();
  list_insert_tail(&hciReadPktPool, (tListNode *)hciReadPacket);
 /* Explicit call to HCI_Isr(), since it cannot be called by ISR if IRQ is kept high by
 BlueNRG. */
 HCI_Isr();
 Enable_SPI_IRQ();
mavv
 Disable_SPI_IRQ();
  Enable_SPI_IRQ();
  Disable_SPI_IRQ();
 BlueNRG. */
 HCI_Isr();
 Enable_SPI_IRQ();
GF
Hi mavv !
When you say "mix BLE + mesh" do you mean that you can communicate with (for example) a PC by BLE and then transfert this message to Mesh network, like that, you can act on Mesh with a computer ?
If yes, is that possible to explain me how you construct your custom ble service pls
