Drivers to configure BLUENRG-2N
malarab
Senior II
is the drivers to configure BLUENRG-2 and BLUENRG-2N are the same ?
can i use the same driver from x-cube-ble2 to make an application with BLUENRG-2N ?
Thank you.
ChahinezC
Lead
Hello @malarab​,
I am not a BlueNRG expert, but you can check the BLUENRG-2 AND BLUENRG-2N document.
Chahinez.
ChahinezC
Lead
Hello @malarab​,
Chahinez.
hi @ChahinezC​
it is not clear in the documentation,
i already started the implementation but it is not working yet !
I don't know if it can be a problem in the compatibility of the driver with the hardware.
Thank you,
