CHIP ANTENNA with S2-LPQTR for 433MHz RX
Posted on April 19, 2018 at 11:10
Hi All,
We are looking for a Chip Antenna for S2-LPQTR. We need 433MHz RX with a 100-200m range requirement. We are using
S2-LPQTR
 since it drains only a low current and it has only a small form factor. We need a chip antenna which can be used for this application. I am looking for chip antenna since we have space constraint reason. We don't have any expertize in antenna designing. So we need your suggestions & recommendations for designing the 433MHz RX with S2-LP. Please provide reference schematics of S2-LP with the chip antenna if there is any.
Any help will be greatly appreciated. Thanks in Advance.
Best Regards,
Krishnaprabha S Naik
#s2-lp #s2-lpqtr
0 REPLIES 0
