I: Case# 00184890 has been updated. [ref:_00Db0000000YtG6._5003W00000QWgmZ:ref]
vincent.rizzo
to reply to your request of information: "One open question for you, what kind of antenna do you plan to use to cover both 433 and 868MHz with a single antenna matching circuitry ?"
I attach a picture of the antenna vertical sleeve @ lampda/4 whip for 433Mhz that we plan to use to cover both 433 and 868Mhz with a single antenna matching circuitry.
Best Regards
Vincent Rizzo
Joe WILLIAMS
Hi vincent.rizzo
Your question is being addressed through the online support interface.  Thank you for your topic.
Kind Regards
Joe WILLIAMS
STMicro Support
