BlueNRG discovery (scan interval) issue
kukushonok
Posted on February 18, 2015 at 12:32
I have some troubles while discovering ble devices:
no matter
what
I set
the interval
scanning (to aci_gap_start_general_discovery_proc function) procedure
lasts
10 seconds
Can I
somehow
reduce the duration of
the scan
Andrei Kukenov
Posted on February 19, 2015 at 12:10
Hi Andrei,
the aci_gap_start_general_discovery_proc procedure is terminated when the procedure Aci_Gap_Terminate_Gap_Procedure with the procedure code set to 0x02 is send or a timeout happens (10.24 seconds).
 Therefore if you want to reduce the scan procedure, you can send  the Aci_Gap_Terminate_Gap_Procedure with the procedure code set to 0x02.
Graziella Marchese
kukushonok
Posted on February 19, 2015 at 13:05
Hi, Marchese
Thacks a lot for your quick reply!!!
 Andrei Kukenov
