2015-02-03 04:07 AM
Hi
I have two BlueEnrg devices (IDB04A1 on Nuclear boards).
Peripheral is advertise data, similar with iBeacon and updates advertising data content every 10 sec. Central starts passive scanning. It should to read and process advertising data, before start of connection establishing procedure.
Packet sniffer shows correct advertising data and its updates (address_type - Public, Adv_Ind, 37 bytes of data, AdvData= 15 FF xx xx �xx -02 01 05-05 12 20 00 40 00).
Central did not find my Peripheral, but at same time , another device (TI Sensor TAG) has been discovered.
Another ''BUT'' :
Central received (from Ti Sensor TAG) event EVT_BLUE_GAP_DEVICE_FOUND with argument type: peer address.
BUT:
Event EVT_BLUE_GAP_DEVICE_FOUND with argument type advertising data never been detected.
SDK: ''BlueNRG DK 1.6.0'' (firmware not changed since purchase )
Central:
aci_gatt_init();
aci_gap_init(GAP_CENTRAL_ROLE
aci_gap_set_auth_requirement
aci_gap_start_general_discovery_proc
Peripheral :
aci_gatt_init
aci_gap_init(GAP_PERIPHERAL_ROLE
MyGATTServicesInit
hci_le_set_scan_resp_data(0,0)
aci_gap_set_discoverable(ADV_IND
#bluenr2015-02-23 06:03 AM
Hi George,
It looks we're experiencing the same issue... Did you solve your problem?Regards,2015-02-23 07:03 AM
Hi George,
could you please give me more details about your HW/SW configuration?On which STM32 Nucleo board did you plug your X-NUCLEO-IDB04A1 expansion board? For example was it a NUCLEO-F401RE, NUCLEO-L053R8, etc?
As for the software, you mentioned using ''BlueNRG DK 1.6.0''. This is not the right SW package for your HW. In your case, you should use the X-CUBE-BLE1 package, instead. Here is the link to it:http://www.st.com/web/catalog/tools/FM147/SC1870/PF261442
Please don't hesitate to ask for more information.
Best regards,
AntonioHi
Packet sniffer shows correct advertising data and its updates (address_type - Public, Adv_Ind, 37 bytes of data, AdvData= 15 FF xx xx …xx -02 01 05-05 12 20 00 40 00).
Another ''BUT'' :
BUT:
Central:
aci_gatt_init();
Peripheral :
aci_gatt_init
MyGATTServicesInit
