Asking the illumination mode of VL53L8CH.
‎2024-05-03 2:04 AM
As far as I know, dToF has two illumination modes. One is spot dToF (iPhone) and the other is flood illumination. Which one is VL53L8CH? Thanks.
- Labels:
Time of flight
‎2024-05-03 11:33 AM
All the DToF chips from ST use a flood-type illumination. The VL53L8CH uses a VCSEL with a native output of a 27-degree cone, and a diffuser that spreads the light into a 45-degree pyramid of light.
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
‎2024-05-29 1:31 AM
Sorry about late reply. Thanks for your answer. I have another question that "a VCSEL" means single VCSEL unit or a VSCEL array? Thanks.
‎2024-05-29 7:33 AM
Let's try to open a new topic once an answer has been accepted.
But to answer your question the Vertical Cavity Surface Emitting Laser is a chip that consists of several cells and each cell emits light. On the VL53L0, L1 and L3 there are 4 such cells. On the VL53L4 which uses a different (single stage) cell there are almost a dozen. I don't know how many cells there are on the L8 though. But the answer is one tiny chip with multiple cells on it integrated into the module.
- john
