Question Regarding Stop Detection Algorithm (CDB-ID 200)
Yegor
Could you please provide more details about the Stop Detection Algorithm referenced in CDB-ID 200? The documentation we have contains very limited information about this feature.
Specifically, we would like to understand:
- What is the purpose of the Stop Detection Algorithm?
- How does it work?
- What are the configurable parameters and their recommended values?
Thank you in advance for your support.
GNSS-LeaT
When enabled, the stop detection algorithm will freeze position updates when there is a 3D position fix and the horizontal speed is < 1.2 kph. The threshold is not configurable for this mode. There is a timeout that will update the position if the stop status does not change for 40 seconds.
GNSS-LeaT
