2024-07-11 7:23 AM
hello
im trying to deploy an AI model in the stm32f407 board that predict if its gonna rain or not based on the current temperature and humidity(either from a sensor or data given through teh serial monitor) (led on if its gonna rain and vice versa) with stm32 cube AI . i followed your tutorial(getting started with cube AI) i installed it ,created a little model and downloaded it as an .h5 file . i followed every other step in the video from project configuration to validate on target . generated the code and everything . now the problem i dont know how to use the model implimented to manipulate the leds through the model results. is there some includes i need to add to the generated code. or some functions i need to call . i didnt know how to give the model inputs and show his outputs. i coudn't know even in which file the model was implimenetd . it seems for me that this part is still a little bit unclear "how to exploit and manipulate the model". so is there ani guide so i can try the model give it some data and he give me his prediction even thrrough the serial monitor.
2024-07-17 8:41 AM
all this is explained in the embedded documentation (in STM32CubeMX just type Help->X-Cube-AI Documentation)
Also you have several application examples in the model zoo https://github.com/STMicroelectronics/stm32ai-modelzoo
The getting started code for several applications is in the stm32_application_code directory
