SPC5Studio example application Error: Cannot load configuration file 'L/SPC56ELxx_RLA ADC Test Application for DiscoveryPlus/configuration.xml':
‎2018-06-29 7:28 PM
Hello (I am new to ST and SPC5Studio)
I just used the SPC5Studio Application Wizard to import the SPC56ELxx_RLA ADC Test Application for DiscoveryPlus and when I tried to generate it it showed the following error:
/SPC5-Config/application/instances/instance[7]/pit_settings/channel_0/frequency: Required Field.I tried repeating the process with the SPC56ELxx_RLA CAN Test Application for DiscoveryPlus with similar results. I can see a small 'x' in front of the configuration.xml file in the project explorer in both cases.
I really appreciate if someone could help me with this.
Thanks!
#cannot-load-configuration-fileSolved! Go to Solution.
‎2018-07-02 1:07 AM
Hello Caio ,
Could you send me the Installation details ?
Could you update SPC5-RLA
http://spc5.drive.cloudforge.com/projects/spc5releases/SPC5Studio/updates5
Best regards
Erwan
‎2018-07-02 1:07 AM
Hello Caio ,
Best regards
Erwan
‎2018-07-08 6:25 PM
Thanks for answering Erwan. I reinstalled it all and somehow it is now working - thanks for your reply and please accept my apologies for my delayed comment - It was my fault that I didn't check it before - I was used with another system from another company that alerted (email) when a question got replied or commented and it just went over my head.
