RTC in low power modes
‎2021-10-03 8:39 AM
Hi
I had a question about RTC in SPC560bxx.
When you read the RTC documentation carefully, you will notice that it is actually a 32-bit counter that also operates in low-power modes and issues interrupts.
This module is just a counter and there is no register to preserve value in low power mode.
Am I right about that?
How to use RTC in low power modes?
Is it used only to wake up the chip?
‎2021-10-11 5:26 AM
Hello Alireza,
You can find a nice example in SPC5Studio Tools suite
SPC560Dxx_RLA WKPU API Test Application for Discovery
RTC Timer is set to 2 seconds in this example
Best Regards
Erwan
‎2021-10-11 5:26 AM
Hello Alireza,
Best Regards
Erwan
