Read UART Data on interrupt in SPC5 controller.
‎2022-03-08 3:28 AM
how to use UARTto receive data on interrupt instead of using this api (sd_lld_read) as this works in blocking mode in while loop.
Micro is SPC560P50L3.
Is there is an example to use the Uart Rx on interrupt.
As we use this method in Stm32.
- Labels:
UART-USART
‎2022-03-17 7:25 AM
Hello ,
I recommend you to use some multi-threads mecanism in some RTOS FreeRTOS-RLA or Chibios-HAL.
Otherwise , you need to redevelop sd_lld_read UART Driver
Best Regards
Erwan
‎2022-03-17 7:25 AM
Hello ,
Best Regards
Erwan
‎2022-04-17 11:02 PM
Hello
Is there any other methods to enable uart interrupt? Like using IRQs or ...?​
