No CAN transmission without loopback in SPC5 studio with SPC58xGxx board
  • November 12, 2024
  • 4 replies
  • 1212 views
In SPC5 Studio, I have an example of CAN communication using the SPC58xGxx board. When loopback mode is enabled, the transmission works correctly. However, when I disable loopback mode, the transmission fails.
Could you provide guidance on how to successfully transmit CAN messages without using loopback mode? Additionally, I would like to know how to monitor the CAN signals using Peak-CAN.
Best answer by praveenaher
Hi jmary,
I was setting wrong clock configurations because our board is different.
If you want to work CAN with NO LOOPBACK, configure your clock according to your board.
It may work, I solved the problem in similar way.
Billy OWEN
Hi @praveenaher
This post has been escalated to the ST Online Support Team for additional assistance.  We'll contact you directly.
Billy
jmary
What the solution for this issue? I faced the same problem with my device.
praveenaherAuthorBest answer
Hi jmary,
jmary
yes, I already found the solution also. correct, the bitrate not match between the device and the usb-can converter I use.
