Library files
ssk
Posted on January 07, 2016 at 11:18
I want to generate library files for my C modules. E.g. I have a C module for timer with functions for initialization, configuration, start and stop. I want to generate a library module which I can use in SPC5Studio project and call the required API from other C modules. Is it possible with SPC5Studio?
Can I build C module to generate library files?
Thanks.
Mike
Erwan YVIN
Posted on January 07, 2016 at 16:12
Hello Mike ,
You should create an alternate project for this :
Script and Makefile
1) generate your .o files by an other makefile
2) ppc-free-vle-ar ruv yourlib.a *.o
   or ppc-cle-ar ruv yourlib.a *.o
In your application :
3) Update user.mak file
# Define ASM defines here
UADEFS      =
# List all user directories here
UINCDIR     =
# List the user directory to look for the libraries here
ULIBDIR     =
# List all user libraries here
ULIBS       =
   Best regards
                  Erwan
ssk
Posted on January 15, 2016 at 10:43
Thanks Erwan. I shall look into building the library files.
Best Regards,
Mike
