I am currently working in SPC58EC MCU using SPC5Studio toolchain. I want to write and read to a register. For example, FLEXRAY_0.PCR0.B.ACTION_POINT_OFFSET = 0x0003U. But UDE debugging is stuck at this line. Does anyone know what is the reason ?
RSeba.2
Erwan YVIN
Hello ,
have you enable the PCTL 0x12B ME_PCTL107 S_FlexRay_0 Control ?
if not , you can generate a data abort to access to this register.
Best Regards
Erwa,
Erwan YVIN
Hello ,
Best Regards
Erwa,
RSeba.2
I did not understand completely. Could you please elaborate ? Generate data abort means ?
I am currently doing the configuration of protocol control registers of flexray controller, therefore I want write many parameters to these PCR registers.
RSeba.2
Thanks. It worked
