How to USE SPC58x MCU to generate PWM waveform up to 50Mhz
Options
2022-02-20 9:58 PM
Hi guys.
I am evaluting SPC58x serials MCU to toggle GPIO pin to generate 101010 data pattern.
It should be meet 50MHz (or 100Mbps).
can it come ture?
1 REPLY 1
Options
2022-02-27 2:08 PM
Have a look at SPC58NN, with GTM running at 200 MHz and ATOM/TOM divider set to 4
please see also the datasheet and the pinout description, only pin with strong/very strong
configuration can reach 50 MHz.
However it is at upper bound limit of pad specification.
