2018-03-19 10:46 PM
Does SPC5studio support print debug message on CONSOLE window by coding, not print message on serial port?
2018-03-20 1:35 AM
Hello Chu ,
Yes , you can install an other plugin to communicate with Serial Port
https://marketplace.eclipse.org/content/tm-terminal
it is working well .. we are using it in our automatic test bench.
Best regards
Erwan
2018-03-20 1:35 AM
Hello Chu ,
Best regards
Erwan
2018-03-20 9:20 PM
thanks, Erwan
A further question, after installed TM terminal. how to print message on it ?
by call function printf()?
