2016-02-03 1:26 AM
Hello everybody,
I am using the external clock option in a evaluation board for the SPC56EL70L5. Thus, I selected ''Oscillator bypass'' in configuration.xml. Even the example projects don't work with that option, while if I left it unselected the examples work only if i put the external clock (this makes me think that because of my jumper configuration I am already working with the external clock). The stack with oscillator bypass is attached.Thank you very much.2016-02-09 2:28 AM
