2020-09-25 10:12 AM
I am trying to upload a code to my SPC570S-DISP development board, but I am having an issue with the debugging tool UDE. I searched for this issue in the forum and I have tried all the solutions given and none of it work. When I try to debug from SPC5Studio I get this error,
And when I try to use the UDE STK tool I get this error,
Message from component 'PpcJtagTargIntf' :
Can't connect target !
No JTAG client found !
Please check:
- target power supply
- JTAG cable connection
- target configuration
I have created a case with ST, and so far no one has been able to figure out what the problem is. As I saw from the posts in the forum, many users are having this problem. Please be kind enough to look into this matter.
2020-10-13 4:03 AM
Hi Erwan,
Thank you for the support. I did a fresh installation of the SPC5Studio and UDE STK on another computer, and tried the debugging process.
I worked like a charm. I have no idea what the issue is with the other computer. Hopefully you could share some thoughts on this issue.
Thank you again.
Nisal
2020-10-13 10:26 AM
Hi Erwan,
I was able to complete the debug process, by changing the COM port assigned to the development board manually.
Thank you
Nisal
