Cross compiling for SPC570Sx without SPC5Studio
Yalin Gurcan
Posted on June 28, 2018 at 11:20
I'd like to cross-compile code without using SPC5Studio for
SPC570S5E1 on a linux box, which version of gcc would I need and what flags should I use? Do I need a special toolchain for the e200z0 core?
Thanks in advance
#gcc #cross-compilation
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
Erwan YVIN
Hello ,
You can find the linux freegcc here :
http://spc5tools.spc5studio.com/tools/freegcc/plugins/
Best Regards
Erwan
5 REPLIES 5
Erwan YVIN
Posted on June 28, 2018 at 16:44
Hello Yalin ,
you can find the freegcc for powerpc vle (linux) in the following directory (cf plugins)
http://spc5.drive.cloudforge.com/projects/spc5tools/updates/
Compilation is OK
for your information we have a SPC5Studio Linux beta version
  Best regards
            Erwan
GCole.1
I have the same problems in order to cross-compile in Linux base environment the SPC570S5E1 with command line, but the suggest source is not longer available.
Can i find the fregcc?
Thanks.
Best regards,
Gianni
Erwan YVIN
Hello ,
Best Regards
Erwan
Thank you Erwan.
Also, is there any st document designed to support command line development in unix environment?
Best regards.
Gianni
Hi, I'm looking for some tool for compile SPC58 on a linux box, no mother if GUI or CLI or java based commands. Something to get out of windows Have you some tool for that. Thanks.
