CAN / CAN-Open / UART Bootloader?
Options
2015-06-26 7:50 AM
Posted on June 26, 2015 at 16:50
I can't find any application note regarding bootloader on SPC56. I'm looking for CAN or CAN-Open or even uart bootlader to reflash my SPC56EL60. Any advise is welcome! Thank you.
3 REPLIES 3
Options
2015-06-29 7:24 AM
Posted on June 29, 2015 at 16:24Hello Aurélien ,Did you check the chapter 10 in the reference manual ?Boot Assist Module (BAM)
Best Regards Erwan
Options
2015-07-22 5:09 AM
Posted on July 22, 2015 at 14:09Hello,You will find the required info in Chapter 6 Microcontroller Boot in ''RM0037Reference manual''Best Regards,Saswat
Options
2017-01-09 1:14 AM
Posted on January 09, 2017 at 09:14
There is a solution using LINflex: search for SPC5-Flasher. V2.5+ supports all families and clock combinations.
