2018-08-30 12:23 AM
Through menu "File->New->SPC5 C/C++ Aplication",Create a new project.But,the result is fail.The error message is"An error has occurred. See error log for more details.Argument cannot be null". I think various methods to fix the problem,but not success. Why? Thanks!
Use spc5 studio5.8
2018-08-30 5:06 AM
Could you please update to version 5.8.1 and try again (help-->check for update)?
Anyway,
you con start developing by using the wizard ("import samples from application library). There you can find hundred of already configured application sorted by platform, board and driver.
