I got the kit with the SPC582 board. it has a usb port, but how does the SPC5Studio connect to it? I did not see any debugger function? Peter
DLaue.1
ATROI
Hi Peter,
The following link:  https://www.st.com/resource/en/user_manual/dm00643538-how-to-assemble-and-use-the-autodevkit-adaptive-front-lighting-kits-stmicroelectronics.pdf points to a User-Manual of Adaptive Front Lighting , if you read the chapters 7, 8 you will find all info you need to start with SPC5Studio and AutoEnvKit.
In these Chapters are described step by step all info you need e.g. :
How to create a new project in SPC5-STUDIO
How to add components to an SPC5-STUDIO project
Component configuration in SPC5-STUDIO
How to generate and compile application source code
How to debug an application generated with SPC5-STUDIO.
For what concern the UDE STK tool (Universal Debug Engine) how download it please see chapter 6.
UDE is the tool used to download the compiled file in to the Micro and gives also the possibility to debug at run time.
Alessandro.
ATROI
Hi Peter,
Alessandro.
Thank you Alessandro, I will download the UDE tool. I tried one version who did not connect to my board, but I saw there were different ones available.
Peter
Dr. Peter Lauer
Senior Specialist Embedded Controls Architecture
SWEC Organization
Industrial Sector
EATON Corporation
7945 Wallace Road
EDEN PRAIRIE, MN 55344
TEL: 952 937-7119
FAX: 952 294-2080
Cell: 612 387-5888
Disclaimer: This message and any files or text attached to it are intended only for the recipients named above and contain information that may be confidential or privileged. If you are not an intended recipient, you must not forward, copy, use or otherwise disclose this communication or the information contained herein. In the event you have received this message in error, please notify the sender immediately by replying to this message, and then delete all copies of it from your system. Thank you.
