2012-06-11 6:45 AM
W
hat is the definition of quiescent current parameters in operational amplifier project?
Thanks, Luli #quiscent-current2012-06-12 12:33 AM
Hello Luli,
The quiscent current is equivalent to the ''supply current per channel'' as used in the op-amps product selector.It represents the value of the current flowinginto the Vcc+ pin (positive supply pin).
Test conditions are: nominal voltagesupply, no load on output pin.Regards,SylvainWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
