Op amp voltage range
Options
2012-06-06 8:17 AM
Posted on June 06, 2012 at 17:17
I am adopting the TS922 family and I have a 16Volt rail on my PCB board. I am thinking to use a rail splitter (+/- 8Volts) or I can always step down the supply voltage if needed. The supply voltage of TS922 listed in the datasheet appears at 2.7Volts to 12Volts. Is this ±12Volts or 12Volts total?
Labels:
- Labels:
Operational Amplifiers
Options
2012-06-07 3:25 AM
Posted on June 07, 2012 at 12:25
Hello Mirmon,
The2.7V to 12V specified in the datasheet is the total voltage. If you split the rails, you need toobtain +/- 6Volts Max or step down the supply voltage.
Regards,Sylvain
