2018-01-12 3:26 AM
2018-01-25 1:54 AM
Hi Sir,
The cutoff frequencies are too high for audio signal (10nF and 1kOhm => 15.9kHz and 1.5nF and 330 Ohm => 322kHz).
If you want to keep the gain unchanged, you should increase the 10nF and 1.5nF capacitors to respectively at least 10uF and 22uF.
Best Regards,
P
