STVD 4.3.0 crash
jaceksien25
Posted on November 30, 2011 at 21:51
I have a problem
with
STVD
4.3.0.
When I try to
open the workspace
the program crash.
Behaves
the same way
when
I create a
new project
and trying to
modify it
in the editor.
The problem
appeared
only
in version
4.3.0,
the previous version
4.2.1
there were no
problems.
STVD
4.3.0
installed on a
freshly
installed
Windows Vista
Home Premium (
installed and
run as
administrator).
The compiler
is the latest version
Ride7
Raisonance
Works on
STM8S
Discovery.
Does
anyone have an idea
where
is the problem?
Thanks and regards
Jack
#stvd-vista-crash
stephane serre_O
Posted on December 01, 2011 at 11:18
Try to remove .wdb and .wed files which have been created by STVD inside your local Raisonance directory. It should solve your problem.
Best Regards
jaceksien25
Posted on December 02, 2011 at 11:56
Thank you
for your response.
You were right.
I removed the
specified files
and
now I can
open the project
but I still have
a problem
with editing
files.
Just change
a few lines
of
code
and the program
shuts down
Best Regards
Jack
