STM8 PWM output TIM2_CH3 over PD2
Options
‎2015-12-10 5:06 AM
Posted on December 10, 2015 at 14:06The original post was too long to process during our migration. Please click on the attachment to read the original post.
Options
‎2015-12-14 12:45 AM
Posted on December 14, 2015 at 09:45
Hi Franz,
Have a look at the option bytes specifically the AFR bits. Hope that helps. IanOptions
‎2015-12-17 6:31 AM
Posted on December 17, 2015 at 15:31
Thank you IAN
I found the AFR2 bit in the small documentation of uP Here the instruction for all with same problem: ST Visual Develop --> Tools --> Programmer --> Option Byte --> set option with right mouse button Register Program Start must be pressed. Finish and it works. FranzOptions
‎2016-02-21 11:18 PM
Posted on February 22, 2016 at 08:18 Hi Franz, I am new to STM8. Are you using IAR workbench for development??? If yes, where to find libraries for STM8AF5288TA. Thanking you.
