STM8 firmware library
d_aliaga
Posted on April 14, 2016 at 09:32
Hello
I have been reading a document called Getting Started with the STM8
and they mentioned the ''STM8 firmware library''
However I have spent a
lot
 of time (really too much) trying to find this library.
Searches inside ST homepage and googles outside proves fruitless
So I ask directly here. Can someone tell me please
where can I find the
Thanks a lot
4 REPLIES 4
Ian Legg
d_aliaga
Posted on April 14, 2016 at 10:35
Thank you very much for your reply.
I followed your link but could not find the libraries.
For example for the first link I found:
-two safety packages??
-A touch sensing library
-A LCD software driver
-motor control firmware
-DALI (??) library
-optimized examples <----- Is this the library I am looking for??
-smart card application
-Audio software codec
-improvement techniques
The second link also provided something as similarly disorganized.
I am reading
http://www.st.com/web/en/resource/technical/document/application_note/CD00194637.pdf
  that makes me expect (from Fig 17) something very organized.
Where can I find and download this firmware library?
Am I missing something?
Did someone change the name of this library?
Ian Legg
Posted on April 15, 2016 at 09:09
The first link I posted was for the STM8S series but you need to look on page 2 and you're looking for peripheral library in the disorganised list. The second link I posted was for the STM8L series and equally if you are using this chip look for peripheral library in the list.
Hope that helps.
Ian
d_aliaga
Posted on April 19, 2016 at 03:10
Thank you for your help
I found it.
However it is not working yet... somehow it does not compile. I will start another thread and will appreciate your help there too if possible
Thanks again
