Period of IWDG issue.
zsu
Posted on December 09, 2009 at 09:48
zsu
Posted on May 17, 2011 at 15:04
Default period of IWDG is about 15.90 ms. I try to change it to 63.70 ms by using instruction below. But it does not work. Its period keeps at 15.90 ms.
Any trick ? Your help will be appreciated.
During debugging, IWDG_PR keeps zero (default value).
IWDG_KR = 0x55 ; // Enable access to IWDG_PR and IWDG_RLR
IWDG_PR = 0x02 ; // divide by 16.
IWDG_RLR= 0xff ; // Time-out period at about 63.7ms.
zsu
Solved. There is a trick.
If you use instruction in order as below, it doesn't work.
IWDG_KR = 0xcc ; // Start IWDG.
To make it work, you have to put instructions in order as below.
:p
baroudi
Hi zsu,
I think you should add
IWDG_KR = 0x55 ; start the IWDG
after
I think IWDG_KR = 0x55 ;doesn't start the IWDG but It enables access to
RLR and PR registers.
Let me know if you have some news.
With regards,
